Changing rooms open but no showers?
5 years 1 week ago#1by Tony Blackmore
Changing rooms open but no showers? was created by Tony Blackmore
Can I ask why the showers are not available when the RYA guidance clearly states that they are allowed to open?
Given the current weather patterns it would seem particularly harsh to keep them closed...
Clip from FAQ from the RYA web site...
Can indoor facilities and changing rooms open? Indoor sport is permissible with no limitation on numbers for organised sport. Changing rooms and showers will be able to open, but you should encourage participants to avoid or minimise use where possible (for example, by arriving in kit and showering at home) and to minimise the time they spend in the changing area. Participants should socially distance whilst in changing rooms. More than one household can use changing facilities at one time, but they must not mix and must adhere to capacity limits which must be aligned with the ventilation rates permitted by the venue.
Tony
B14 788 - Admiral Trailers
5 years 1 week ago#2by Alistair Glen
Replied by Alistair Glen on topic Changing rooms open but no showers?
Changing room and showers at our gym are fully functional and not many people come out of a Pilates class suffering mild hypothermia!
5 years 1 week ago#3by Michael Bagge
Replied by Michael Bagge on topic Changing rooms open but no showers?
Just so you are all kept up to date. We will be opening the use of the showers as soon as practically possible, but we have a (legal) duty of care to make sure that the showers are safe, having been left out of use for over a year. We have to have the water properly tested for bacteria, such as legioaires disease and to make certain that it is OK for everybody to use. With current timescales this is unlikely to be until after June 20th.
Thank you.
Michael Bagge
5 years 1 week ago#4by Alistair Glen
Thanks for the update, Mike.
5 years 1 week ago#5by Tony Blackmore
Replied by Tony Blackmore on topic Changing rooms open but no showers?
How come the testing is taking so long?
Tony
5 years 1 day ago#6by Olly Turner
Replied by Olly Turner on topic Changing rooms open but no showers?
Will the showers be available for the Merlin open? Or is there a way of having them tested in time?
I can imagine no showers being a bit off putting for visitors.
5 years 1 day ago#7by Olly Turner
Is that not the same hot water that we're using to wash our hands?
5 years 1 day ago#8by Michael Bagge
The earliest we can get the boiler fired up and tested, is tomorrow. The earliest we can get the samples to be tested is Tuesday. The earliest they can give us our results, depending on the two tests, is 10 working days. The other (Legionella analysis) is 15 working days. If all is OK then that is fine, if they find traces, etc. longer. The Legionella need 10 days just to grow. That is the science. So the short answer is no.
I hope that answers your questions.
Michael Bagge
